difference between s13 and s14 KA harness
jaidedeye
Car: 84 s12 200sx
what is the difference between the s13 and s14 KA harness's....i have a 95 KA24de engine, harness and trans im going to do a KAT-t in my 84 s12..
im just trying t figure oit what the differences between the s13 and s14 harnesses are.
thanks
Philsnotfalling
Car: 90 hatch 93 coupe
I'm not for certain on some of the plug shapes but I know the s13 will have an aiv unit plug and an external pick-up coil for the distributor. other than that I think is just plug shape.
jaidedeye
Car: 84 s12 200sx
Philsnotfalling wrote:I'm not for certain on some of the plug shapes but I know the s13 will have an aiv unit plug and an external pick-up coil for the distributor. other than that I think is just plug shape.
so could i just run an obd 1 s14 ecu in my s12 and be ok? i will also ask on club s12
Florida240sx
ECU plug...coil plugs.. Going to be a couple extra for emissions and 2nd 02 sensor...
jaidedeye
Car: 84 s12 200sx
Florida240sx wrote:ECU plug...coil plugs.. Going to be a couple extra for emissions and 2nd 02 sensor...
so using the s14 ecu and harness with the s14 motor in my s12 what all would be different, i figured the snd o2 sensor...what else?
Florida240sx
If you got the motor... you shouldn't have to worry about anything really. Just wiring to get your fuel pump to work unless you hot wire and depending on if you use you a s14 clustr then you need the dash harness or do it custom..
jaidedeye
Car: 84 s12 200sx
Florida240sx wrote:If you got the motor... you shouldn't have to worry about anything really. Just wiring to get your fuel pump to work unless you hot wire and depending on if you use you a s14 clustr then you need the dash harness or do it custom..
ok, thanks...the fuel pump will be hot wired more than likely....about the cluster....i was reading on clubs12 and found out that the only thing that wont work is the tach...
at any rate, yeah i have the motor,harness,transmission and motor mounts, all i need is an 0bd1 s14 ecu
