Difference between Red and Black top?
Gozma
what exactly is the difference between a sr20det s13 redtop and black top?
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
nothing but the color of the paint on the valve cover.
Blacktop is from the 180sx redtop is from the 'old school' silvia's.
PaulOrlando, FL
I H8 UR DSM
there are minor differences...and the blacktops ecu has some differences
Gozma
why does the blacktop cost more?
I H8 UR DSM
comes outta 97-98 180sx
redtops come from early year silvias
Emperor240
that isnt true, the red top has a stronger head but a weaker turbo then the black top, so the black top makes more power and cost more. but if you wanted to tune its best to go with a redtop and just put a bigger turbo on it because the head is strong :bonghit
I H8 UR DSM
well who ever told you that is wrong, and i and everyone else would rather you not go around spreading false information. what do you have to back anything like that up?
the S13 red and blacktop motors have identical heads. (high port flow)
the s14 and s15 motors use a low port head design which is different, but not neccessarily and stronger or weaker.
and it doesnt necessarily have a 'weaker' turbo either, its a different turbo, and one is ball bearing also...
nice hubcapse.
"comes outta 97-98 180sx
redtops come from early year silvias"
and you are saying that isnt true also?? whats wrong with you,a nd were do you get your info?
I H8 UR DSM
Emperor240 wrote:that isnt true, the red top has a stronger head but a weaker turbo then the black top, so the black top makes more power and cost more. but if you wanted to tune its best to go with a redtop and just put a bigger turbo on it because the head is strong :bonghit
i think you are under some misunderstanding of the question and basics in the first place.
A S13 redtop is one motor.A "Blacktop" is a S13 motor also, just a blacktop, out of newer 180sx's only...
S14 is just an S14 sr20det, not called a S14 blacktop
same with S15, its just an S15.
so basically your response it totally wrong, both, the redtop and blacktop both put out the same amount of power.....and have the same turbo, but different ecu
s14 and 15's have different turbos and ecu's and heads and intake manifolds
SR180SX
Black Top!!
I H8 UR DSM
hey sr180sx, you have a AIM account?
SR180SX
no, what's AIM?
I H8 UR DSM
aol instant messanger.
email? just have some questions for you, about the Sard FPR
SR180SX
I H8 UR DSM wrote:aol instant messanger.
just install the AIM, my user id specrs14
RedStage
Car: Cars
Actually the RPS13 Blacktop SR started in 1993 or 1994. Think late 93, the same year the S14 Silvia came out.
My 180 is a 94 and has a black top. Between the Red and Black tops from S13's there is only mild differences, I've been told that the porting is better on the black top and that there are some other issues that are different, but both are tuned for 205ps....
Daunttless
94 was the first year of the blacktop. : )
RedStage
Car: Cars
Thought so. The 9/93 would be the 94 sales year.
Oversteer
Car: Drifting
Let me try to get this straight:
The blacktop is newer then the redtop, but other than that, the only difference is the type of turbo.
The blacktop is generally more desirable though, because its newer.
Correct?
Cyberkreig
Car: 1993 Nissan 240SX SR
Oversteer & that kid that was TOTALY wrong.. Go to http://www.srswap.com Read the FAQ & Engine Specs.
SR180SX
SR180SX
Oversteer wrote:Let me try to get this straight:
Correct?
same engine, turbo, injectors, etc. S13 black top just newer that's all, i think you confuse between S13 black top and S14/S15
Oversteer
Car: Drifting
I was talking about only the S13 black&redtop.
Thanks for the link.
I H8 UR DSM
just the ECU is different, and minor differences like cadium or whatever plated bracketry, and some visual distinctions. All S13's have the same turbo, internals, etc.
