Postby
silviagtr96 »
https://forums.nicoclub.com/silviagtr96-u31733.htmlTue Nov 08, 2005 8:06 pm
is the rb20det and rb25det harness the same or similar how can you tell what harness you have ,and will and rb25det harness work for rb20det motor or will rb20det harness work for rb25det motor
Postby
USMCgetsome »
https://forums.nicoclub.com/usmcgetsome-u15451.htmlWed Nov 09, 2005 12:36 pm
the plugs that terminate into the ecu are totally different. The rb20det is split into 2 parts. The rb25det is 1 single plug. Essentially the same wiring i'm sure.
