IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Fri Nov 14, 2003 9:21 pm
yup. ive been studing the r32 gtr service manual, and the front drive is connected through a clutch pack and drive chain, so it has no effect on the rear drive wheels.
thank you for answering my question, i was worried if one version had a substantially stronger motor than another. i would really like a r34 setup just for the 6 speed, but im gonna toss the turbos, gonna need a custom exhaust, and im not going AWD, so all the goodies id be paying extra for i would wind up not using. that would be one hell of a waste of money. im sure everyone would love to see a 6 speed awd J30, but im not even gonna start trying to make it awd. im gonna have enough trouble as it is with the rest of it.
also, what im contemplating is using the gtr transmission in rear drive [removing the front driveshaft, drive chain, and differential from the oil pan] and converting to manual. seeing as how the J30 is a front sump oilpan setup now, its gonna work out on that end.
basically my outline that im gonna work with-z32 iron calipers, rotors, ss lines, 1" master cylindercustom stainless dual 2.5 inch exhaust with dual N1 style muffleraluminum radiator [transmission cooler omitted]gtr or upgraded FMICcustom fabbed motor and transmission mounts, driveshaftKAAZ 1.5 way lsdhicas eliminationmanual transmission/gtr or z32 brake and clutch pedals/bracketsrb26dett, gt2530 turbines**, 660 or 720 cc injectors, walbro FP{metal head gasket, HKS cams [undecided]}unsure on wheels, but 17 inch front/rear with 255/40-17 rearsslightly stiffer rear sway bar from non-touring modelstock ride hight.
**[if anybody cares, i can get garrett gt turbos about the same specs as gt2530 for half the price. they are stock mazda protege turbos. two bolt compressor in/three bolt compressor out|t25 flange/5 bolt exhaust housing]-and they are brand new. ask for info if your interested
im sure i left out somethings, but that should do a good job of making me broke.
if all goes well and i get it completed, it should be running by late spring.
edit- i left out the ECU. im undecided on which way to go with that.
