Does anyone know what differences there are between the 01 Pathfinder VQ35DE and the 350Z/G35 VQ35DE?
I saw somewhere online that the VQ Nismo cams wouldnt work in the Pathfinder heads.
I have an blown pathfinder VQ with good heads, but a cracked block and destroyed internals, I was hoping to get a used block with damaged or no internals, so I can build up a VQ to swap into my 85 300ZX. But if aftermarket cams wont work in my heads, then there is no point in building an engine with the heads I have.
Also, does anyone know if there is a way to disable the VTC? I was planning on running Megasquirt, but as far as I know there is no way to run MS with a VTC engine.
