Difference between 92 and 97 KA?
Nismo240s
Car: 92 240sx SE, 96 Maxima GLE, 05 Titan SE
Are their major differences between a 92 and 97 KA? I have an extra 92 engine and might decide to build it for my 97, if it would work.. thanks for any info
Billy
kamikazestorm420
92 dohc is obd1 and the 97 is obd2
Nismo240s
well I realize that, I Just wanted to know if they would change out... basically if the block and the head (except for cams) are the same
driftaholic
Car: '91 Nissan RM S13
s13 has an external coil, and s14 has internal. there may be wiring harness issues because of that. i don't know if that makes any other parts different though. i've heard of people using s14 motors in s13's and s13 motors in s14's so it CAN be done.
InsanityInc
You mean the ignition coil?
Nismo240s
Yeah, S13's have an external, S14's have the coil inside the distributor...
SX APPEAL
Car: 06 G35 Coupe 6MT
95 Maxima SE 5MT
Arent the S14 KA's also rated at 5 more bhp? 155/160? What is the reason for that I wonder.
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
Both s13 and s14 ka24de motors are 155hp
SX APPEAL
95 Maxima SE 5MT
Oh, ok then. Im just the new guy lol
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Nismo240s wrote:... basically if the block and the head (except for cams) are the same
Basically, yes.
The head is a different casting (different valve cover bolt pattern) but is otherwise identical.
There is a very minor change in the upper front cover...although they look identical, they are not. If they are swapped, you will leak oil everywhere from right near the distributor. FYI...
The bock is also identical in most respects...
There are no advantages to either block, except maybe the age of the '97 versus the '93.
And the OBD thing...it's brought up EVERY time someone asks about a motor swap (KA --> newer KA, or the opposite)...and it ALL ELECTRICAL.
Just because one came in a car that had OBD-I and it's going into a OBD-II car....since the head and block are basically identical, the ECU and OBD is none-the-wiser.
When you swap, retain the intake and exhaust manifolds with the chassis, and use the same ECU and electronics...doesn't matter which head/block you use. ECU can't tell...
- Brian
