DMan II-40 wrote:S13 runs 240/248 CamsS14 runs 232/232 CamsAlso in 97 and 98 they made it have duel timing chains.
The cam swap that has dynoed the best is 248/232. And the reason the valve covers don't fit is because the S14 ones has one extra bolt hole in it. And yes, in 96 they added OBD II emissions. The 95 Ka is OBD I/OBD II since they were produced in 94 they only put half of the OBD II equipment on them (*atleast I read that somewhere)
The s13 has dual timing chains upper as well
RCCC_DRiFteR wrote:I just remember there being something fish about the intake manifolds being differnt though!! cause my friend bought a long block '96 DOHC motor and we found out that the s13 manifold wouldn't fit due to studs alignment or something like that. it was like 8 months ago its hard to remember exactly and the valve cover shape is different so thats why it doesnt work from a s14 valve cover to a s13 valve cover
Thats odd... Xcessive manufacturing makes that intake manifold for the DE's and it works on all of them.. And its using the stock upper part of the manifold... I believe it should work fine i dont know what problem you ran into though..
DMan II-40 wrote:
Dude, if your going to build up the engine you should run something better than a T25. I'm only doing T25 because I only want low boost for DD. Just so you know you will need more than E-mance, SR 370cc, T25, and a walbro. I assume you know that tho. And if you don't....well you have a lot of reading to do.
What else do you suppose i need? besides all the obvious stuff that im not going to sit here and name.. Im running either a JWT ecu or an E-Mance tune and ill get a wideband and stuff and the motor internally is going to be fully built low comp pistons and stuff... What else are you thinking i need? I know about all the oil line routing and everything but what are you hinting towards..???
