Issac »
https://forums.nicoclub.com/issac-u89863.html
Sat Mar 29, 2008 8:49 pm
I keep seeing this question pop up and do not have the answer. But the thing that counts is getting your power up it sounds like. So if that is the case, then why not forget about the auto, which I would never take over a standard anyway, and do what you can to bring that up?A lightened flywheel from JWT and cams and intake/exhaust will get you way over 10hp and you can forget about Autos because you will be long gone. I would speculate that the auto tows less due to clutch slippage or something, but you can change that. Standard is king, and although I do not have one, my question is how to get Standard characteristics and not Auto.It aint the power difference that makes the towing I suspect.
