difference between 08 Altima 3.5 to 06 350Z 3.5
Discuss topics related to the VQ series engine.
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
I know both motors are VQ35DE motors but what's the difference between the two? :gotme I'm sure one of the differences is the ECU tunning. And if so, what's different about the tuning. Cams, different piston arm lengths? :confused: Sorry if these questions sounds newbish. Is there a tutorial or write up on this already? Trying to do research between the two to see if it's feasible to do a swap or just get brian crower cams and re tune the engine with and AEM EMS..
Thanks in advanced guys! :bigthumb:
proto45
Car: S14 soon to be swapped... for an RB26!
im not sure but i believe that the compression ratio was different on the two motors, also i think the cams were a tad larger for the 350z/g35 i have a set of 350z cams for sale if you want them.
trigger_storey
Any updates on this? I know someone who as a set of TOMEI cams out of a 06 350z that he just just put a supercharger on and chose to put a different set of cams in. Will it work on the coupe or not....
Return to “VQ30DE / VQ35DE / VQ35HR Forum”
