f s t caz »
https://forums.nicoclub.com/f-s-t-caz-u11665.html
Thu Feb 19, 2004 6:03 pm
i'd say expect more than $1500. For me, it was close to $1600 shipped for the motor set. Then I bought $400 worth of maintenance parts(waterpump, timing belt, tbelt tensioner and idler, thermostat, new plugs, valve cover gaskets, seals). Then keep in mind you'll need piping (i didn't get any w/ my motorset. you might be lucky, or might want to run other than factory, and need custom piping made) and an intercooler. Then, are you going to want to run a factory exhaust? no. you're going to want to upgrade. more $$. Then there's the other stuff; oxygen sensor, a new turbo, boost controller, boost gauge, you might edn up needing a clutch and possibly a flywheel, gear oil, maybe motor/trans mounts, vacuum lines, new hoses, this that and other stuff you don't think of before hand but will start to add up when you're trying to finish the project on limited funds.
Just trying to point out that it costs more than just the cost of the motorset. It'll make it into the car for $1600, but I'm not sure if it'll drive.
