SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Mon Mar 01, 2004 3:27 am
So you have a RWD 200SX from Europe with the CA18DE(T)? Imported through military?
Copied from somewhere else (doesnt cover details of S14 or S15 SR's)...
Wiring from the 1991-1996 SR20DET's is different. The 1997-1998 wiring is pretty much the exact same, the difference is the pinouts on the ECU. From what Jeff at HT has indicated in the past, if you end up getting a late model ECU and have a redtop/early blacktop SR then you dont need to acquire a new ECU, you simply have to repin a couple wires. BTW if you use the late model ECU on an early model S13 SR only the first cylinder will fire.
Layed out in uber obvious terms (Turbo models only):1989 S13 Silvia CA18DET 175 hp 167 ft lbs1989 S13 180SX CA18DET 175 hp 167 ft lbs1990 S13 Silvia CA18DET 175 hp 167 ft lbs1990 S13 180SX CA18DET 175 hp 167 ft lbs1991 S13 Silvia SR20DET Redtop 205 hp 203 ft lbs1991 S13 180SX SR20DET Redtop 205 hp 203 ft lbs1992 S13 Silvia SR20DET Redtop 205 hp 203 ft lbs1992 S13 180SX SR20DET Redtop 205 hp 203 ft lbs1993 S13 Silvia SR20DET Redtop 205 hp 203 ft lbs1994 S13 180SX SR20DET Blacktop early model 205 hp 203 ft lbs1994 S14 Silvia SR20DET Blacktop with VTC, 370cc's and BB turbo early model 220 hp 203 ft lbs1995 S13 180SX SR20DET Blacktop early model 205 hp 203 ft lbs1995 S14 Silvia SR20DET Blacktop with VTC, 370cc's and BB turbo early model 220 hp 203 ft lbs1996 S13 180SX SR20DET Blacktop early model 205 hp 203 ft lbs1996 S14 Silvia SR20DET Blacktop with VTC, 370cc's and BB turbo early model 220 hp 203 ft lbs1997 S13 180SX SR20DET Blacktop late model 205 hp 203 ft lbs1997 S14 Silvia SR20DET Blacktop with VTC, 370cc's and BB turbo late model 220 hp 203 ft lbs1998 S13 180SX SR20DET Blacktop late model 205 hp 203 ft lbs1998 S14 Silvia SR20DET Blacktop with VTC, 370cc's and BB turbo late model 220 hp 203 ft lbs1999 S15 Silvia SR20DET Blacktop with VTC, 480cc's and S15 BB turbo 250 hp 203 ft lbs2000 S15 Silvia SR20DET Blacktop with VTC, 480cc's and S15 BB turbo 250 hp 203 ft lbs2001 S15 Silvia SR20DET Blacktop with VTC, 480cc's and S14 BB turbo 250 hp 203 ft lbs
Another great source in chart format is...from the New Zealand site
