Diff wiring??
tireslayer325
Car: '93 S13 coupe
Just bought this 300zx LSD although im wondering what the wiring is for on the back of the diff? i searched and saw that most TT 300zx's had this wiring but didn't see any NA's with it. Its supposedly an NA diff. Im swapping this into my s13. Is this still compatible?
blkvrtswp
Car: 93 240SX Convertible
SR20DET FP 20G Turbo
It's for ABS. You might need a shorter ABS driveshaft.
biggie
ABS sensor being on the back of the diff shouldn't affect driveshaft I wouldn't think.
And shouldn't you swap the rear cover for an S13 one? Therefore getting rid of the Z32 rear cover and the ABS sensor?
blkvrtswp
Ah, that's right Z diffs have ABS on the sides, sorry! It's the 240SX diffs that have ABS on the input.
OP - got a picture?
tireslayer325
Car: '93 S13 coupe
http://i615.photobucket.com/albums/tt23 ... 026-10.jpg
Heres the URL to the same diff. Thanks for the input, so does my 240sx diff cover match up with the new 300zx diff?
biggie
If its an NA Z32 diff its a R200 and the S13 cover will need to be swapped on so you have the 4 studs to mount it to the S13.
Believe you have to use J30 axles with it though (someone correct me if I'm wrong there).
