Diff / Transfer case oil
Rockhoundrob
Car: 2009 Nissan Rogue SL
2009 Rogue SL
I plan to change diff and transfer case oil tomorrow.
The Hanes manual says to use "API GL-5 80W-90 Hypoid gear oil"
I got a Valvoline API GL-5 80W-90
.... but I do not see "Hypoid Gear Oil".
Is it critical to use "hypoid" ?
Iheartjeeps
Car: 1995 Nissan 300ZX Z32
2015 Nissan Frontier Pro4x
2014 Nissan Rogue Paperweight
As long as its meets the GL5 Rating i wouldnt worry too much about the hypoid bit.
Definition of Hypoid: a bevel wheel with teeth engaging with a spiral pinion mounted at right angles to the wheel's axis, used to connect nonintersecting shafts in vehicle transmissions and other mechanisms.
So I think "Gear oil" covers the hypoid criteria.
Rockhoundrob
OK GREAT !!
Thank you. I tried looking it up thinking "Hypoid" was a type of oil.
Return to “Rogue Forum”
