diff question?
turbo2nr
Car: 97 240sx (kouki)
im purchasing a j30 vlsd 90-94it has the 5 bolt axle flange i dont have the axle's
can i just swap out my open diff output shafts in place of my vlsd output shafts? or will it now work>?
also can i use n/a 300z tt axles?
thanks
Harman850T5
Car: 2003 350z
http://ka24development.com/vlsd.htmlThat's what's helping me through my j30 experience. I know if you're swapping the guts into your open diff, you have to use the output flanges from the j30. So I don't really think that putting your 6 bolt flanges in place will work.
I'm not 100% sure though.
adrianfromthecastle
Car: 1992 Nissan 240sx
I'm not too possitive with s14's... because I believe s14s have different diff mounting locations...
but as far as using the z32 axles, z32 axles are longer than j30 axles. just an fyi
turbo2nr
my damm heads spinning.. grrr
ok so if i get this j30 diff, can i take it out of the j30 pumkin with the 5blot flanged axle and install it into my open diff 6 blot flanged axle pumkin?
or can i just use n/a 300z axles?
im taking the diff out the pumkin to shim it anyway so if it will make my life easier to just put it in a s14 pumkin then ill do so instead of looking for j30 axles.
thanks
Harman850T5
Car: 2003 350z
from what I've read, you have to use the J30 output flanges no matter what. So you can put it into your open diff pumpkin as long as you use the j30 output flanges. If you click on the link in my first post, it may be of some better help.
