SinceByMan »
https://forums.nicoclub.com/sincebyman-u7337.html
Mon May 17, 2004 6:07 pm
First, I used search.
Second, how do I change the fluid in the diff. I looking in my chiltons and it had 1 diagram of a IRS diff and said check the fluid using the rear plug and also use the rear plug to fill. I got under my car and noticed there are two plugs, one on the rear and one on the side. Is the rear plug for draining, or checking? Is the side plug used for filling? How much fluid goes in? I read that its 1.5L and also, is 75W-90 an ok weight?
