diff. in responce with Sr T25 VS SR T28 On the KA24DET?
The All Mighty KA-T
Car: 1995 Eclipse GS-T
I'm wanting to know the diff in responce in the sr t25 vs the sr t28........like what RPMs does the T28 kick in......i know the sr t25 hit boost at like 2,200 RPM's........i'm about to start up my T28 setup and i just wanted to know what RPM's im going to be hitting boost at.......thanks guys
One more thing.....is the Sr T28 WaseGate Spring set at 7 PSi like the SR T25???
david200095367
Car: 91 fastback 93 coupe w/s14 sr20det 98 s14 kouki
i have a s14 t28 bb and it starts spools below 2k rpm. Also the wastegate on the t25 and t28 is set to about 7 psi. but on my ka it creeps to 9 psi by 5k rpm.
hannibal
Car: Red Line to Glenmont
I have no experience with either, but I doubt there will be more than 200rpm difference. The biggest difference in the turbos will be top end flow. Good purchase, IMO...
david200095367
not exactly true. the s14 and s15 spool way faster because they are ball bearing.
The All Mighty KA-T
i was thinking the same thing......well hell.....looks like i'm selling the s15 T28 and going with a T25....... i'm not in the mood to have boost at 1500 RPM's and have to drive my car daily.....thankd for the help guys......i guess i should have asked this question 1st before i bought the turbo......oh well......live and learn....
david200095367
how much for the s15 t28?
RPS1392
Car: 2X 1992 S13 Fastbacks
Trade ya, T25, 73,000miles on my SR clip. Im looking for more top end on my KA-T
The All Mighty KA-T
how much do you want for your T25......i think my T28 is sold....i have cash in hand
geofthriller
Car: S14
yo, the s14 t28 is not ball bearing, the s15 t28 is.
serial numbers:466541=ball bearing466543=bush bearing
you can also tell on the internal wastegate (hot side) if there is a splitter between the spool and the flapper door
WDRacing
Doesn't matter if they are BB or not, both of those turbo's are to small for the KA. Unless you're only looking for a low boost setup, like no more then 8 psi. After that its just to much back pressure and it becomes a heat pump as well.
WD
hannibal
Its funny to see how much I learned in the past 9 months. LOL!
WDRacing
I know, at first I was like...wtf, where did this come from. Then I saw the dates.
Anything SR related automaticlly makes your 240 Queer, its like a STD
WD
PapaSmurf2k3
Site Admin
WDRacing wrote:Anything SR related automaticlly makes your 240 Queer, its like a STD
WD
Sig worthy Right there!
