I have fitted a harrop 9" Billet Aluminium Diff to my 1994 Q45, with a Tru-Trac 31 spline helical gear LSD. The set up works really well with OEM Ford Nascar 4:11:1 gears.
The diff is really quiet most of the time, which surprised me, given the diff is solid mounted. After hard driving, the diff whines at certain rev ranges. I assume this is due to the Redline oil thinning out as it heats up.
I have purchased the 300ZX diff cooler kit.
Before I fit it, I would appreciate any feedback from members on the effectivness of Diff coolers in cooling the diff oil.
The only reason I am considering fitting it is to reduce the noise when I have been driving the car for extended periods.
Please note the picture below is the same diff housing as mine, but in a different vehicle. For a larger image, click on the picture.
http://www.harrop.com.au/produ....html
Regards
AGM
