Kansei240sx wrote:Here's my question, i've got a 91 and i've got a super hicas VLSD from another s13, now the gearing is really short for the RB's transmission, for instance, my rpms are really high compared to speed used to be with my KA . 3000 used to be just around 68-70 mph and now its more like 3700 for 70.
I'm not sure what you think the transmission has to do with it... almost all trannys are 1:1 in 4th gear (or 5th in a 6 speed). Trannys do have slightly different gearing, but overall, if you're doing 3000 rpms at 70 mph in 5th on one transmission then you'll likely be really close to 3000 rpms at 70 mph on any other transmission. In 4th gear you'll be doing EXACTLY the same rpms at any given speed. The transmission is there to give you good gear spacing. Spacing is the key. You want 4th to feel about as different from 3rd as 3rd feels from 2nd. Absolute speed is thus irrelevant since you can change all of that with the final drive ratio.... but still the spacing will feel about the same. So forget about the transmission differences.
So I don't think what you said is correct. AFAIK, all 240's came with 4.08 final drives. That means that if you do 70 mph at 3000 rpms in 4th with a non-LSD from an S13, then you'll be doing 70 mph at 3000 rpms in 4th with any other S13/S14 diff (LSD or not), regardless of the transmission and engine that are in the car.
If anything, you'll want a higher ratio now that you have an RB25, not a lower one. This is because the power band occurs at higher revs. So you want your wheels to spin slower... otherwise it will take you longer to get from say 3rd gear to 4th gear. You don't want to be doing 40 mph in 1st before you even climb into the power band, do you?
So what you have is a higher ratio than before, and that's a good thing. For an RB, you want to be revving higher at 70 mph than you did with your KA. Again, that is a good thing.
However, something is not right. Either you didn't have a 4.08 diff before or you don't have one now. It's possible that you got a 4.36 diff from a Skyline. If you find out that it is a 4.36 and you'd rather have a 3.93, let me know and we can swap
