Diference between a automatic tps and a manual tps?
ricanflava
Car: 1992 240SX SE COUPE
Hey guys, i got a 92 coupe with a KA24DE, with a five speed swap. Now my question is: is there a difference between a auto TPS and manual TPS? and if there is do i need to change out the wiring harness and ecu to put the new TPS. I order a new TPS that's auto since the car was auto. I'm stuck and yes i searched and nothing..can some one put me on the right track...
sean@z1
Car: 1993 240sx
I would say yes since the AT part# is 22620-45V00and the manual one the part# is 22620-53F00
Gabes13
Car: rb20det s13
If there wasn't a difference Nissan wouldn't make 2 different kinds.
ricanflava
Thanks!!! Now to sell Her!!
j-z
Car: 95 240sx
just a FYI... i used the auto TPS when i did the 5 spd conversion on my s13. i didnt notice anything different and the voltage checked out right within factory spec.
mrgreeneyes
Car: ///M5
Parted Out Built S13 Coupe
3 wire vs 6 wire
Chris28
Car: 92 s13 KA-T
Difference is like 80 bucks. AT uses 6 wires like senor greeneyes said, but it's basically 2 plugs with 3 wires each. I have a 5sp conversion as well, and I am running the auto TPS because I didn't feel like switching them out. If you need to replace it get the 5sp TPS because it's cheaper, you will just not plug in one of the plugs. Car runs the exact same.
ricanflava
Thanks for the help guys!!
