Wc240 wrote:you may have your gear wired to a hot wire. as in hot at all times. should only be hot in run.
me personally, anything that high, with car off, after an hour of sitting there, is couse for concern.
let your car sit for a day, check what the battery is at. charge it fully, then let it sit for a day after you unplug the controler, and check the battery again. kinda a ghetto way, but i dont know your tool setup/info base, hope that helps
well, i talked to glowshift gauges today and asked them how many mA does their gauges draw while the cars off. thinking that they wouldn't be able to give me an answer or tell me that they would call me back, the guy answered the question without hesitation. He said that the gauges draw 40mA each while the car is off. Wow that's a lot of mA's for such a little gauge. next i need to get in touch with DIF and see how much mA's their unit is supposed to draw while the car is off.
