Featuring new DIF Turbo Oil & Coolant Lines. These turbo lines are made exclusively with Goodridge stainless steel hoses and aluminum fittings. They are made in-house by Goodridge and pressured tested for leaks and durability. Stainless steel braided lines are flexible making it easy to work with and save time when installing a new turbo or engine swap.
DIF includes the proper restrictor size depending on the application. Restrictors are made of stainless steel and less susceptible to cross threading compared to aluminum ones. They come in different sizes for Non-Ball bearing and Ball Bearing turbos, as specified by Garrett.
These lines are for S13 SR20DET Engines with NON BALL BEARING and Ball Bearing Turbos, and comes with the 0.062 and 0.032 restrictor size.
Coolant Feed & Return Line Feature
* Goodridge 336 Forged Cutter Design Hose Ends w/ 360 Degree Swivel * Goodridge Stainless Steel Braided Lines w/ 6000psi Burst Pressure * Goodridge Premium Quality Anodized Aluminum Fittings * Fireproof Silicone Sleeve for up to 2000 Degrees F Flame Protection * Premium Copper Sealing Washers * Pressure Tested
Oil Feed Line Features
* Goodridge Premium Steel Crimp Fittings * DOT Approved Teflon SS Braided Lines w/ 12750 psi Burst Pressure * Goodridge Banjo Bolts w/ Premium Copper Sealing Washers * .062" and .032" Stainless Steel Oil Restrictor Fittings * Premium Copper Sealing Washers * Pressure Tested
** Must be used with stock OEM oil feed banjo bolt. **
Please Call In For Upgrade And More Details.
For A Limited Time We Are Offering 15% Off On All DIF Turbo Lines Until August 31st. Use Coupon Code Below For Discount.
Coupon Code:DIFTurboLines
Thanks,FRSport.com Team
AIM:FRSportSalesEmail:[email protected]
