Dif and trans sealer
emptyhead
I am about to service my 2 difs and trans and tranfercase on my 04 frontier crew cab. What type of gasket sealant are you guys using on your difs and transmission. Also what type of transmission fluid are you guys using in the transmission and transfer case.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
Auto or stick?
The auto takes Dexron III and the manual takes GL-4 (no substitutes, it has to be GL4.
You shouldn't need to reseal anything to do a drain/refill. If you do remove covers, etc., standard blue RTV silicone works fine.
The Tcase can take 75 or 80W90 GL5, as can the diffs. The Tcase will take 2 quarts, the front diff about 1.75 quarts, and if the rear diff is an H233B axle, it takes about 2.5 quarts.
Of course synthetics are better.
emptyhead
It is an automatic
hsckris
Car: 07 V8 4runner
Desert Rat wrote:You shouldn't need to reseal anything to do a drain/refill.
+1 -- didn't on my 06.
Desert Rat
2017 Frontier 4.0
2008 Boulevard C90T
unless you have a purge system like the trans shops use, dropping the pan will only drain about 1/3 of the fluid. It's almost worth it to head to Aamco or the like and get one of their purge specials for $99-129 and get a full fluid replacement.
hsckris
Car: 07 V8 4runner
Or you can drain/fill & drive & repeat. I personally think that 30k is pretty early for a flush.
