So GT2554R alone should solve my problem, right? From what I'm reading it's more than capable of doing 200HP, and I'cant really imagine how GT3071R installed behind it could help with anything under 4000rpm.D_Stirls wrote:Meminto beat me to what i was thinking. 50+psi through compound turboing. you need a small turbo for you primary turbo, something like a GT2554R and something large like a GT3071R as the secondary, but you'll make more than 200hp.
Read through this: http://www.ka-t.org/forums/viewtopic.php?t=7446Thradya wrote:So GT2554R alone should solve my problem, right? From what I'm reading it's more than capable of doing 200HP, and I'cant really imagine how GT3071R installed behind it could help with anything under 4000rpm.D_Stirls wrote:Meminto beat me to what i was thinking. 50+psi through compound turboing. you need a small turbo for you primary turbo, something like a GT2554R and something large like a GT3071R as the secondary, but you'll make more than 200hp.
Not to mention they use insane amounts of ALS, that's why they have 300 BHP flat on tap all the time.Sil240 wrote:If I were you I would look into a CA20 Crank.
Don't know anything about CA's but if the CA20 has more Stroke then the increase in stroke will give you a better mechanical advantage.
That and a small turbo would be killer
Also if you look at WRC cars they make 300 HP but something like 400 ft/lbs of torque
They used restrictor plates and variable boost controllers
The GT25R is basically the stock replacement, so you would get stock spool, power and torque (or lack thereof, more accurately). Maybe slightly better spool, because of the ball bearing. Which is still nothing like what you've outlined in your original post. For your original goals, it's really better to start with a KA (maybe build the high compression engine), this engine just isn't fit for that.Thradya wrote:CA20 is not available around here. Compound turbo, after some reading, seems to make sense in big turbo applications - i.e. small turbo is helping the big one, not the other way around.
Let's assume that single, small turbo is the way to go - are there alternatives to GT2554R that would suit my goals and not require new headers?
Engine will be running on MS/VEMS. What other stuff need to be changed? I'm completely new to CA18 and have no idea about it weak design points.
