RBrum wrote:figured out some of it. the battery was low and old so i bought a new one.. still didnt fire up but you could tell a difference. took each plug out and they where covered on s*** because the car runs so rich. cleaned them and wire brushed them and stuck them back in and car started right up. still hesitated if i give it gas real quick but runs better. now its finally home waiting on new nismo injectors, circuitsports fuel rail, new plugs, and coilpacks
Modified by RBrum at 2:34 PM 1/1/2010
I had an issue like this when I would give it more than 1/3 throttle the car would start to bog.
Have you replaced the 20 year old plastic intake piping that goes from the turbo to the MAF sensor? When I had a friend give it throttle I could see the Intake piping sucking closed. It was like sucking a frozen milkshake through a straw. The center of the pipe would suck closed. I recently replaced mines with an aluminum pipe. I hope this helps.
