Dies under deceleration!?!
apex_7
Car: 240sx
Has anyone else had this problem? Any suggestions?
Also, My Turbo timer (apex'i) reads off 02 sensor voltage. Well, it's a/f ratio reading is 20.0 under normal driving and 14.6-7 under full boost. Why? If that were the real a/f ratio, wouldn't it have blown up already?
It idles all funny, but I'm replacing the plugs tomorrow. Maybe that'll fix that problem.
The car stays on for two or three seconds after I turn it off, so when the turbo timer shuts off, it stays running and just starts counting down again. Does anyone have a solution to this.
Please help!~Tony
YamaOni
Car: Its ugly and green, Its a cefiro dori machine
Where does the BOV vent? Back into the system or to the atmosphere?I had that problem when I vented the BOV to the atmosphere
YamaOni
apex_7 wrote:Has anyone else had this problem? Any suggestions?
~Tony
You are running lean in boost, As long as you are in negative boost the A/F does matter as much, My Gready A/F is 14.7 At idle and under Boost I am running a little too rich at 11.5. Your factory O2 sensor is keeping you at 14.7. thats a good burn but not that good for power.
apex_7
Car: 240sx
The BOV vents back into the system. So how do I change it to where I'm not running so lean?
YamaOni
SAFC The stock ECU wants to be at 14.7.
FAST-DATSUN
Check the fuel pressure and fuel volume, timing.....
apex_7
Car: 240sx
I don't know where to get the stock specs for that stuff. What should it be at?
YamaOni
At idle 2 kilo and under boost up to X and stop but not drop
FAST-DATSUN
Idle speed stock 650 rpm
timing 15 degrees at 650 rpm
fuel pressue at idle with vac 43 psi -+ 5 vac off rise should be 5-10 psi
factory spec's key on pressure 3.0 kg/cm2 idle 2.55 kg/cm2vac off 3.0 kg/cm2
Mack @ Mckinney Motorsports
apex_7
Car: 240sx
Thanks Mack!
