died and back again.. what happened?
canadian booster
Car: 1993 Nissan Z32 TT JDM
i was driving to work and as usual my speedometer jumps to 180 (i was doing 50) and after a couple of mins my hicas light comes on.. fearing trying to park with the steeringwheel so stiff, i do what i usually do.. put the car into neutral while it's rolling, turn the key and power off, then fire her back up and away i go with a reset speedometer..
problem is that i haven't done this since last summer, when i tried today, she didn't start up again. I had to get guys to help me push and pop the clutch and start her up that way, went for a drive around the block, parked, turned off, started up again no problem.
i was going over it in my head trying to see why it was sitting dead. On a side note: i found a speed sensor for sale in california (used) it's coming in the mail....
CrazedZ32Owner
Car: 91 Z32 TT(no motor), 2008 350Z Nismo, 05 Pontiac Sunfire speed machine!!! :)
could it be the ignition switch is failing?? just trying to help you get ideas here
canadian booster
it's weird tho, works fine now, just drove home from work. i mean, it runs fine apart from only getting 6lbs of boost, heh, damn leak.......
NolimitZ32
You have a gremlin,
1)find it
2)kill it
3)grill it
4)profit
LOL
Dude sounds like an intermittent electrical issue, maybe a wire rubbed through somewhere and shorts out from time to time, or you got a corroded wite somewhere that looses continuity as it heats up could be a ton of things. I had a similar problem in my WRX and it turned out that my main starter/engine ground was so badly corroded inside that under no load it showed .0000001 ohms but as soon as any voltage was put to it the resistance jumped to 40,000 ohms. After replacing it I cut it open and everything was green and nasty.
canadian booster
i've got a speed sensor (used) coming from CA so that'll give me a reason to slide under there and closely look at all the doo dads and wire thingies under there :D
es.biggs
Car: 1990 300ZX 5sp NA
Starter relay could be on the way out?
canadian booster
es.biggs wrote:Starter relay could be on the way out?
i've driven it every day since then, and she's been fine every time. i can only assume 'gremlins' at this point. Damn You Gizmo ! Don't put water on him, or feed after midnight pls thx
