charlieo wrote:My labor isn't included in the budget!
I got a free toilet paper roll holder tonight, made from scrap
I needed one, and I had the stuff to make it. Damn were people giving me weird looks when I told them what I was working on. Cheapness of DIY FTW. [/f***ing random]
rcabrita wrote:Yea I remember reading your resonces in the engineering forum
To be honest I don't fully understand what you wrote.I also found this
http://forums.nasioc.com/forum...07570But I am not sure where exactly they speak of Major Thrust
Its really not that complicated man. You know, you push on something... it pushes back on you. The connecting rod is held by two pins, so the only direction it can push is along the line that connects the two pins it rotates about. As the piston moves through its stroke the connecting rod is only vertical at the top and the bottom. When the connecting rod is not vertical the force it pushes back with on the piston is aimed off to the side.The force on the top of the piston only pushes directly down, so the piston is pushed at an angle into the side of the cylinder wall by the connecting rod.
Think of it like pedaling a bike. when you step on the pedal it not only moves down, but forward as well (as the pedal rotates through its circle its not JUST moving straight up and down.)Well the piston wants to do the same thing, but the cylinder wall stops it.
