Did some more testing
rb250sx
Car: '89 s13 w/ RB25DET
'07 Nissan Frontier
'14 Jeep Rubicon
I did some more testing on my MAF circuit, and this is what i got. Power to the MAF was 12V when i ground it right to the battery, but There seemed to be a bad ground going back through the plug(only getting 3.5V) Sometimes when i would test it at different parts of the circuit I would get 10V but that seemed to be a fluke. traced the ground all the way back to the ecu, where i even touched my ground lead to the metal pin inside the ecu box, and the biggest drop was 4.5V while i still got 12V when ground to the battery. If i used the ecu ground (pin 50 and 60) i would still get my 12V drop so i dont think its a bad ground TO the ecu. Seems like my MAF curcuit is shot?
btw, i thought last weekend when i tested across the plug i got 12V, but maybe when i switched the power and ground it finally did in the circuit? and seeing i was getting 8V at the signal pin with only 3V drop at the MAF to the ground, there was obviously a short between the power and signal wire which seemed to be in the ecu as well.
Modified by rb250sx at 6:24 PM 6/11/2005
Modified by rb250sx at 6:25 PM 6/11/2005
rb250sx
'07 Nissan Frontier
'14 Jeep Rubicon
Anyone have an 25 S2 manual ecu they dont need? or possibly someone thinking of going ems that would like to get rid of a PFC?
eh?
when you removed the maf plug did you still get a voltage reading at the ecu signal wire?
