matt4pl »
https://forums.nicoclub.com/matt4pl-u4587.html
Thu Jul 13, 2006 7:05 pm
ok so i installed itb's on my KA. its a 96 with all the good ole OBD2 junk, but nothing was hooked up except the essentials (MAF, O2), afterwards it started overheating, so i stopped driving it anywhere except to work and back (4-5 blocks). didnt even get a chance to heat up.
i have no leaks, the coolan/heater lines are hooked up in the same way as stock. i replaced everything: radiator, water pump, thermostat, all lines. car also runs very lean.
i dont see any leaks and in the past week when i replaced all the cooling stuff, fuel filter, and O2 sensor. i looked over all my vaccum stuff and its all fine. FPR is hooked up to all 4 runners, new fuel filter. i connected the IACV, MAP/baro system, and evap system. egr is totally out save for hte solenoid. compressions came back 170-180 across all cylinders, no mixed fluids AFAIK
took it to a shop (hated doing that) and had em check for a blown headgasket. they didnt do a leak down test but said they had a machine for that sorta thing and didnt find anything that would suggest a blown HG.
im totally lost, this doesnt make sense, at all, cause well, if it did i would have fixed it. maybe this belongs in the nissan tech forum but i dunno, its late, im tired, sick of the car, going to bed...
