As part of one diagnostic it states to put a plug in pin 37 i believe and other to ground, (MAF testing) once this is done, start the car and let it idle, you should approximately have 1.5v well I'm reading 3.7v what's the deal?
Also someone said that I could have had my b/w wire exposed which is power for alot of things. Well I did a continuity check from the ECU pin all the way to the plugs and had continuity. The specific plugs were the CAS (cam angle sensor) and the MAF sensor.
