Also, what about all the other service times on the schedule...I'll never make their estimations right now. My Rogue will always be low mileage, it's just how I drive, or rather don't.
HarryGI got my rogue on April 29,2009 and so far it has less than 1500 km on it...i only drive to school which is about a 15 minute drive, or around town, maybe a short highway trip once a month...anyways the dealer sent me the a little letter stating that i was due for service..i know the first service is supposed to be at 6000km, and that there is a special oil that helps with the break in period, which is already in it....so would it be alright if i waited til the 6000km mark to get the first oil change or should i go in sooner???
found the response from philipa to my question (seems similar to your situation)Short distance city driving is actually quite hard on the engine and the oil. 15min is not enough time for the engine to properly warm up. As a result, accumulated gasoline and other contaminants from cold starts are diluting the oil instead of being evaporated and burned off. This is weakening the oil's lubricating properties and could damage the engine.
I would try to get some longer distance/duration driving in if you can. Possibly on a weekly basis.
Another concern is the effect such short distances will have on engine break-in. A few longer city trips (not highway) with lots of stop and go driving will help with this. This will help to seat in the piston rings and other components so you get the best 'seal' and improved fuel economy and performance.
As for the oil changes,
Without doing a used oil analysis, it hard to recommend something. With such short distance driving, duration becomes more important than mileage. Here is what I would do:
- Get a clean plastic bottle/jar that holds about 120ml (about 4oz), with a good lid (screw cap). Hint: look at food containers, etc at the grocery store.
- Do an oil change as the dealer suggests. I also recommend going for a minimum 25 minute drive, immediately before your oil change to evaporate any gasoline in the oil. This is necessary for proper oil analysis.
- As the oil change is being done, ask them to collect an oil sample using the bottle you provide. The oil should be collected as it is draining from the motor. Don't scoop it from the pan or collect as soon as it starts draining.
- Send your oil off for analysis. There are many labs, here are a few:
http://www.wearcheck.ca - Located in Burlington, Ontario, Canada
http://www.blackstone-labs.com - Fort Wayne, Indiana, USA
When you get the analysis back, please post the results here. Then I can recommend how frequently you should change the oil.
If you don't want to go through the trouble of oil analysis, then stick with the 3 month oil change interval. Yes, it's frequent but I am quite concerned about the short distance driving you are doing.
Unless all of those miles long trips (>20min), then absolutely change it even at such low mileage. Short trips are a killer for engine life for the reasons I mentioned above.MadHungarian wrote:THAT is the question. It seems to me that changing your blended or fully synthetic oil every 1750 miles is just a bit much!
If not to maintain the warranty, then do it for the longevity of your car. If you consider that four oil changes a year is about $120-$150, it's cheap insurance compared to replacing a $5K motor. If that isn't enough reason, then I don't know what to say...- Repeated short trips of less than 5 miles in normal temperatures or less than 10 miles in freezing temperatures.
- Stop-and-go traffic in hot weather or low speed driving for long distances.
