s14ben wrote:Sounds like you have a good reason to do a tune up now as well. at least new plugs and wires. Just make sure not to get the cheapest wires in the parts store. Those things blow.
Good point I actually went ahead and bought new plugs before I bought the gasket. It seems no one sells the spark plug gaskets seperately, the entre valve cover gasket has to be purchased. I went ahead and changed the plugs and car ran fine. Of course I wont be driving anymore until I get the gasket switched, so the money I just spent on the plugs wont be a total waste.
Now I've stumbled upon the guide chain article. I dont feel advanced enough to remove the side guide, but I think I will remove the top guide. As far as I know I havent been getting the rattling noise yet. But since I will already have my valve cover off, is it likely I should be able to get some WD-40 or seafome on my chain tensioner? As preventive maintenance?
zerothread?id=105618
Thanks so much for everyones help!
