RickBlaine »
https://forums.nicoclub.com/rickblaine-u221531.html
Tue Sep 15, 2015 8:10 pm
Thank you gents, I drained the oil/gas mixture out of the crankcase (8 quarts total- yes, 2 gallons!) and then identified and replaced the stuck fuel injector. It smoked like crazy for a few high speed runs, then settled down.
I was worried that with all that gas in the crankcase, I may have allowed some of that oil/gas mix to seep down the valve stem seals and maybe find its way into the intake or PCV valve.- but after those few runs at wide open throttle- all is well. No oil burning, compression is excellent, and she idles like new.
Point is, if the engine is running rough, don't just assume you need new plugs and wires and drive it for a week while waiting for the delivery guy to drop off your NGK wires, plugs, and cap & rotor. It may be a stuck (open) injector.
Seriously, 2 gallons of fluid came out and smelled like Shell gasoline. I could not believe it. Bet the engine is super clean now, ha ha ha.
I will search for resetting the ECU- thank you, did not think of this. It may help as the car may have learnt some bad habits with that old faulty injector.
