DID I JUST BLEW A HEAD GASKET?
D180SX760
Car: 1990 240SX HACHBACK
I drove the car for like 2 hours. the car had oil and water before i drove it. And i decided to see what my top speed was with the new ka24de we swap in. well it topped i guess beyond 120. i never noticed any overheating. i decided to stop at some gas station. After i turned the car off i couldnt get em to start. so finally a while after the car cooled down i put some water. The car started and it ran for a lil while but i decided to stop again and i cheked the oil and the oil started to look like chocolate, the water got into the oil i guess. so u guys think That i blew my piston rings and head gasket???? what can i do to fix the problem so it wont happen again
teddy
Car: Saab Turbo and MR2
If there's oil on the tips of any of your spark plugs, it usually means that you're getting pretty bad blowby or one of your rings is gone.
A ring going out wouldn't cause oil to mix in with the coolant though.
180fan
Car: 89 fastback
sounds like a hg.
winez31
Car: 1993 s13 ka24de
hmmm milky coolant=blown headgasket
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
D180SX760 wrote: i cheked the oil and the oil started to look like chocolate, the water got into the oil i guess. so u guys think That i blew my piston rings and head gasket???? what can i do to fix the problem so it wont happen again
Do a compression test on all cylinders to determine if you've got a blown head gasket. You might also follow that up with a leak down test to determine if you got bad rings.
If you have to replace the head gasket, make sure the head surface is not warped beyond 0.1 mm (0.004 in).
When torquing down the head, follow the procedure as outlined in the FSM.
