MCorlione wrote:Problem 1 - the passanger front axle goes in and out of the differential way to easy. It was out when I brought it in. Anyone ever tackled this?
Not sure I can be of much help here. I've never seen the front diff for the 4WD. I'd imagine you might have to open the diff to figure out why its not locking into place.
MCorlione wrote:Problem 2 - there may be oil leaking from the timing cover or the differential, but hard to tell as the power steering line is leaking (getting fixed at $450 locally) everywhere. Anyone ever tackled that?
First step should be to determine what kind of fluid it is. Gear oil has a distinct noxious smell. Motor oil is fairly mild. Though, it could be hard to tell if the leak is light.
MCorlione wrote:Problem 3 - The ride is throwing me all over the place. Does this edition have different shocks/struts, and if so can I replace them? Talked to 3 dealerships and got 3 different answers.
If its anything like the OE shocks on the Titan, then they are junk. They work well when new, but based on some research, it seems the OE Titan shocks use foam instead of a spring or nitrogen pressure to keep the oil under pressure. When the foam breaks down, it no longer adds pressure which allows the oil in the shock to aerate as it passes through the valves. I recently swapped my shocks out with Bilsteins and they made a huge difference as my stock shocks were toast.
