Acecool »
https://forums.nicoclub.com/acecool-u46759.html
Mon Oct 29, 2007 10:22 am
RB20DETintos13 auto to manual
GROUNDS:::Ok, I grounded the engine from the enginemount.I grounded the igniter box to the chassis where the old ground was leading off to the ka..
WIRES:::I wired fuel, temp gauge, orange (choke), the auto jumper so it cranks with key, plus the 3 wires from the other connector...
Whats wrong:::It will crank no problem, I smell fuel, but it will not fire up..
leads me to believe there is no spark...
Should I take the fuel wire off, take the coils and sparkplug racks out of the engine and turn it over to see if there is spark or not?
I tested the coils and the resistance between pin 1 and pin 2 are 1.0 if I set the meter to the correct setting.........
Would power only go to the igniter chip box if the the car is being cranked, or if it is in the on position (so I can better diagnose it..)
Also, I may have forgotten to hook one wire up, where does this go?
And here is the ground:::
