The how to here will only enable you to do the following:
Foglights on by themselves
Foglights and parking lights on
Foglights and headlights
To get foglights and high beams you need to take apart the trim around the steering wheel and ground the switch ( i didnt feel light doing this nor do i really use my highbeams anyways )
Steps:
1. Locate relay box in engine bay - drivers side.
2. Remove Fr fog relay and air con relay.
3. You need 3 male spade connectors that fit in the 2 bigger slots and 1 smaller slot where the foglight relay goes.
4. I used 16GA wiring i reccomend you do too.
5. You need 4 female spade connectors to plug the foglight relay into, again 2 bigger ones and 2 smaller.
6. Cut 3 strips of 16GA wiring about 3-4in long, then one about 5in.
7. Strip ends of 3 shorter wires, attach female spades to one end, male spades to the other.
8. I didnt buy aftermarket relays, you just need to cut away a small square from the blue housing on the air con relay. ( seen in later pic )
9. Take the 1 longer wire strip both ends, attach 1 of the smaller female spades to one end. Other end used to solder onto the cutaway part of air con relay.
10. Hook up all female spades to foglight relay - 2 big to 2 big male spades, 2 small to 2 smaller ones.
11. If you are looking at the foglight relay in the relay box, the longer wire of the 4 will hook into the small male spade on the relay to the left of where the relay clip goes ( aka one closest to you ).
12. Solder other end of long wire to the cut away on air con relay.
13. Hook the rest of the male spades from shorter wires into the slots where the fog relay sits.
14. Put electrical tape over solder point, insert aircon relay and leave foglight relay flipped in an empty relay spot.
15. Fog light drl mod done! Test to make sure before closing everything up.
Pics in order:
Update: Better pic of relay box
Will post up better shot of relay box tommorow, these are crappy iphone pics.
Questions/Comments welcome.
