I have had P1145 and P1140 since 2008.
I replaced all 3 camshaft sensors and 2 crankshaft sensor but codes were still there.
Followed diagnosis again and couldn't figure it out so I took it to local dealers few times and they couldn't figure out either!!!!
I gave up chasing the code since it seems like there is no problem of running at all - maybe fuel economy went down little bit. She has been running perfect until last year.
Pathy throw another code since Nov 2010; P1320. I had misfiring on couple of cylinder so I replaced all 6 coils out and misfire is gone but still had the code. I performed diag further and replaced MAF, Igniton Condensor since they had problems as well. But still have the P1320. I gave up again since there was no problem of running again. Idles find, runs fine and can pass other vehicles on Highway no problem.
For the last 3 months, there was anothr problem. This time it actually gets little more serious and stressful.
It started with engine stall at stop light and sometimes it dies on me. So I had to re-start the vehice. There is no problem with re-starting and once it is up she runs fine again. It happened once in every couple weeks. and now it gets little more frequently. Sometimes on a cold start, she is got rough idle or even engine stall. RPM drops all the way to 250 - 400 rpm and eventually dies on me. There is no problem of starting again. For last couple weeks, she is got even worse that on a cold start I can't rev up more than 2000 rpm. Then I will have to restart - shut off - restart cycle few time and keep try reving up. Once she revs to 3000 rpm and up she runs nice smooth again.
I cleaned throttle body and intake manifold with couple chemicals and tried injector cleaners couple times already.
I was wondered if any one had similar symptom as mine and how you solved the issue.
Did anyone have P1320, P1140 and P1145 at the same time? How did you solve the problem?
I love my pathy but she has been giving me enough headaches recently. I have replaced so many parts and I don't want to spend too much on faulty diag again. Last time when I took it to a local dealers charged me $400 and still couldn't figure out the problem.
I need some help down here if anyone have good idea about it please let me know.
