did any one has this problem
lowblocks
Car: 1995 maxima
ok i know this isnt the right place for this but yesterday i cleaned the trottle body on my moms 2002 altima and now the car rpm's are between 1500-2000 when the car is in park but when in drive the car runs fine i took to my friend shop and he said just drive the car then i took it to auto zone and they put it on the machine and it said the car could have iac leak or a bad iac motor or a dirty throttle body can some please help me
Klepton
Car: 1999 Infiniti I30 (Limited Edition)
I have the exact same problem. Mine started happening a couple of months ago when I also cleaned the IAC Valve, but in addition cleaned the Throttle Body and the MAF sensor as well. I wasn't sure which one of those three procedures caused the problem since I did them all at once. However, since it seems like you only cleaned the IAC Valve on your car, I will assume that it was also the cause of my problem. I want to start reading up on how to adjust the Idle speed so I can lower it to normal, but I don't understand why I'd need to do that if I never increased it to begin with...all I did was clean the TB, IACV & MAF.
Modified by Klepton at 12:29 PM 12/20/2007
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
There's a little screw on the throttle cables that controls the idle speed.
You could tweak that. I had this problem too. Now my car start idling at 1500 rpms and gradually lowers after it warms up. Once it's hot it idles at around 650-700.
I wonder if reseting the ecu would make any difference. It's possible that the ecu has been running the engine harder to compensate for garbage build up and now that it's clean, doesn't know what to do.
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
Check the throttle position sensors too
lowblocks
Car: 1995 maxima
but my moms doesn't have any cables on her throttle body she has a 02 altima
Sentientbydesign
96 I30 - Sold
Good point. They are drive by wire.
Can someone chime in here with some info lowblocks?
lowblocks
Car: 1995 maxima
no one to help me i got on the belt parkway with the car and drove for like 3 hour at 80-85 mph but nothing change by the way what is a iac motor please help car is about to go to the dealer i dont want to pay all that money
