johnny5 wrote:im gunna say yea the engine will run, but itll be horrible since its meant to be run with f/i so to get it to run good with out f/i youll need a retune and different internals so your best bet is to buy a turbo for it if you buy the motor
you can change compression ratio with the ECU?IrenicShogun wrote:Changing your compression ratio would work, but that's all ECU again.
jmac636 wrote:I agree that you shouldn't run the motor out of the car. If you really won't the engine get the guy to do compression test and a leak down test. Also ask him to guarantee the motor will run without a knock when installed correctly. Other than that maybe remove the valve cover and oil pan to verify the motor is good. Also look inside exhaust ports for carbon build up and oil residue and this will give even more pease when handing over your hard earned cash.
Yeah sorry man but there is no ecu tune that is going to change the compression raito.IrenicShogun wrote:
He's not putting the same turbo back in there, what do you mean? Of course it matterscarkook wrote:
What are you talking about? ECU is to piston as piston is to compression ratio, like you said. I know what a CR is.carkook wrote:This is off topic, but the compression raito is how much volume is in the cylinder with the piston at the bottom of its stroke compared to how much volume with the piston at the top of its stroke. Explain how an ecu tune is going to change that.
You're making it sound like you can change the CR by tuning the ECU, which is impossible.IrenicShogun wrote:
QUOTE]
What I was trying to say
