Closed minded? Right. You don't need two turbo's to have a "great powerband"on a small engine.. and upgrading a single turbo doesn't automatically mean you're going to have a huge spool up and no respectable powerband. That is not what I meant, and if that's what you're thinking, then I think you should reevaluate your definition of closed minded and see how well that fits yourself.SeVa-S13 wrote:If that thinking is true, then all the GT-R and Supra owners that upgraded to bigger twins are retarded, right? What makes this idea viable is the fact that besides the downpipe, it's relatively easy to do because the manifolds are already made and fit (with a spacer mind you) instead of wasting a ton of many on a custom twin manifold which is the only gripe with basis against inline engines going TT. The parts are all available, and relatively cheap if you have either a hook-up or watch on ebay long enough.Don't be so closed-minded. With this setup, an RB20 could easily reach 400hp and have a great powerband, unlike those who go with the huge T3/T4's with awful trims and don't start spooling 'til 4k.
Contradiction LOL. I don't think I came through to you on my post, it's obvious. "Lets" not try to act condescending here either, neither of us are children.SeVa-S13 wrote:Let's not infer what isn't there. I never said you needed two turbos for a nice powerband or that two were even better than one. (I myself am going with a single for my 20)
I'm just damn tired of people bashing the idea just because the engine is a whole .6 liters smaller than the "massive" RB26. You ask what two turbos could give what one turbo could not, and then say that a single turbo was not "practical" enough for Nissan to use on the GT-R. Let's try to to keep the contradictions to a minimum.
Seeing that my main point was grossly missed, let me remove its meticulously devised veil ( ) and say it as simply as possible. --Two or one, they both work. They both have advantages and disadvantages.
(To be honest, I don't think there's any real merit in swapping from a single to a dual setup other than bling factor. Despite the modest response gains, the heat and fitment would probably discount any advantage. The only reason I think the GT-R setup isn't a bad idea is because all the parts are already somewhat accessible and the turbos are a decent upgrade over stock. I know you said that the Twins on a 20 would make for an "AWFULL" powerband, but when upgrading turbos on cars, don't most people get a larger turbo? Thought so. And that's what? a .3 liter difference per turbine? People are constantly taking turbos meant for larger engines and applying them to their cars because they want more power. Plus, the GT-R turbos are ball bearing and have ceramic compressors so spool and response should be pretty damn acceptable to an enthusiast looking for an upgrade. Not to mention the bishez that swoon when they see two snails. )
Probably.. and I'd bet a single GT28R would be even more efficient unless you're really inclined to get 600hp out of 2 Liters.Carl H wrote:i bet a pair of gt28rs turbos on the twin setup bolted up to a rb20 would do quite well.
Dunno if that was just a mistake but the GT-R turbos are smaller than the stock 20's T28/T3 Hybrid thinger.Nameless EJ6 wrote:
I am aware of the reason for putting a bigger turbo on an engine to make power. But putting TWO bigger turbos on a 2 Liter engine is rediculous.
i totally agree.dekand wrote:The point is, you could get a nice single turbo and get just as good of a power band and hp gains for WAY cheaper than the TT setup, it is just not practical. Aren't the adatper plates from Underground like 400$ or something ... thats a bit rediculous, I couldn't find it on the site but i seem to remember them costing that much, because you still have to buy the turbos...
Point is, get a nice single turbo and save your money, the outcome will be the same or better if you choose the right turbo.
ok, I made a mistake. However, on an inline 6 non sequential twin turbo, both turbo's make combined power. So add the specs of the GTR turbos together and compare them to the T3 hybrid they use on RB20/25DET's. It might be a good basic upgrade if you plan on running 15psi... but I certainly don't see a point on two Liters. The GTR twins would likely be too laggy and unefficient untill they're fully spooled..SeVa-S13 wrote:
Turbo's are far from technologically advanced. The concept of a compressor has been around just as long as combustion. The only real tech about a turbo is its size.TheOne™ wrote:its a 6 cylinder, not a 4 cylinder civic........it'll be able to use a TT setup with 2 small turbos and it'll make good power.
displacement doesn't always replace technology.
Between physics and 500cc/cyl vs. 333.33cc/cyl there are a lot of differences in a 2L 4 vs a 2L 6cyl.Nameless EJ6 wrote: And if you understand firing order, you'll see that a 6 cylinder is the same concept as a 4 but with two more cylinders. So ya, a TT 2 Liter 4 cylinder is just about the same as a 2 Liter 6 cyl TT.
I'll continue to disagree untill someone proves me wrong. Which it would be quite hard to prove me wrong because of all the variables and technicalities. Two turbo's on a 2L engine is going to lag down low, big time. I wouldn't be suprised if they make good power up top above 5k.. but the powerband will be nothing like a GTR without it's displacement. You don't even need physics to explain that. More torque and combustion gasses = more efficiency in the turbo/s. Without the same amount of combustion and exhaust flow in the 2.6, the turbo's, which were made and specified for a 2.6L engine, will lag down low. Turn up the boost you might see a small gain, but doubtfully anything special in the low end.rbsileighty wrote:
A set of small, well spec'ed T25's would do wonders on a 20... if you were going to run recycled turbo's (ie GTR turbos) I agree that you shouldn't waste you time and should just use that money you saved for a RB25, Z31, or 57Trim T3/T4 turbo with some new brake pads and rotors or brake kit to slow the now faster car down.
I'm not attacking you bud... so no sore feelings ok. I've missed things in posts and replied wrong before, so I thought you might not have noticed what I had said.Nameless EJ6 wrote:Yes, I can read.
I agree with "waste of time"... but that's plays into my disagreement with anyone who wished to throw two turbo's on a 2L engine.
Once I buy my house at the end of 05 or beginning of 06 and things start settling down again... this was what I planned on replacing my T3/T4 with...BoostsFed wrote:the only way to really find out the result is, "just do it".....
