mello88 »
https://forums.nicoclub.com/mello88-u18450.html
Thu Oct 30, 2008 1:10 pm
Not enough info IMO... Could be all kinds of random stuff causing your issues.
Start with the basics, pressure test your intake system and eliminate any leaks. Check out fuel pressure (43.5psi/3bar at idle with vac hose unhooked from FPR), check out your base ignition timing (usually 15* on mt). Pull the codes from the ECU if possible. If all that stuff checks out then look at the idle air setup and/or test sensors. The FSM has a big troubleshooting section you should reference. Good luck
Modified by mello88 at 12:36 AM 10/31/2008
