DaveVQ »
https://forums.nicoclub.com/davevq-u100582.html
Thu Jul 17, 2008 1:26 pm
nope, the b-pillar is actually just tape, if you open the door and look on the inside you can see the line of tape so with a finger nail you can basically peel it up. It takes a little while to do, you can get some nice strips going then it breaks and then there are sections that remain stuck under the rubber stripping, so i used a combination of credit cards and razor to pick out the little pieces left. Lastly there will be some residue so you need to use some goo gone to get that goo off. I have a few little scratches from doing it so I buffed them out with some rubbing compound.
