Did a dumb thing - drove with oil cap off
nabril
Car: 2015 Nissan Rogue SL
good morning
I write to vent and learn, after doing something really dumb 2 days ago.
I was adding oil-additive n the engine, had to leave in a hurry, so I left. I drove 30 miles or so.
The next morning, I discovered an oil stain on the floor under my car. It wasn't a thick puddle, but it was noticeable nonetheless. I opened the hood and also noticed my engine covered/sprayed with oil and the cap off. Instant panic and elevated heartbeat. Where could the cap be in those 30 miles? - was my first thought.
I looked around the engine's holes, and thankfully found the cap. I had some of the same synthetic oil in a container, so I filled the 2 quarts that remained in the container; the dipstick shows the oil within the range. I then wiped the floor and the engine as best as I could.
1. Should I bother to degrease the engine? Everything under the hood has a haze of brown color on it which I figure will eventually burn or dry off. Should I worry about belts and spark plugs? Why did oil spray out? Because of pressure in the engine???
2. Did I cause any damage? The car starts and runs fine thus far, so this might be a moot point.
Yes, I'm an idiot....
Svtrit
I highly doubt you damaged anything if there was still 2 quarts left in the engine. I’d put the cap back on and use some Simple Green to clean up the oil mess. It may take a few cleanings.
I like to spray down the engine bay with SimoleGreen, let it sit 10 minutes, then hose it down. I do that a couple times a year and my engine bay stays clean as a whislte.
You’ll smell burning oil for a LONG time. Oil takes forever to burn off the exhaust.
You shouldn’t need any additives. Modern oils are more than adequate for our little engines.
nabril
Svtrit wrote:
Wed Jan 10, 2024 11:42 am
Thank you Sv
This is what the engine looks like now i the attachments. Everything has a yellowish hue. Would you degrease it??
I still see oil below the right side, and I assume that it will continue to drip off engine parts vs a leak.
I thought that adding high mileage stp oil treatment would be helpful.
Svtrit
I would. That oil film will collect dirt and become a mess in the future.
Good luck!!!
nabril
Svtrit wrote:
Wed Jan 10, 2024 2:38 pm
Good luck!!!
Thank you very much
I found an engine degreaser at HD by Simple Green. I will spray it and let ot drip on a cardboard box.
I assume that I SHOULD NOT rinse with water, right? Or with a light spray???
Svtrit
I rinse with water. Don’t direct spray your alternator. Water spray won’t hurt it at all. You may need to do a few soaks and rinse to get it clean. Take it for a 15 minute drive when you are done to makes sure everything dried out.
I just picked up a 2017 F150 and the engine bay was very dirty. I did the Simple Green soak, and also used a soft bristle brush to scrub the flat surfaces, valve cover, fuse box, and air box. Since it is cold here I had to use a bucket to dump water on the engine bay. I had no problems at all. A garden hose won’t hurt your engine. I would not use a pressure wand at a car wash though. That would be too much pressure on the electrical parts.
Good luck with your cleaning.
casperfun
Car: 2009 Nissan Rogue SL AWD - Indigo Blue
I agree with a degreaser. Then go to car wash and pressure wash 6 feet away like your lightly coating the engine to wash it away.
Brush and cover things your paranoid of ruining with tinfoil.
Never did it as a routine but when I did, never had a problem. :werd: :naughty:
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
Brake cleaner on a rag and wipe off if near electrical stuff.
For bare metal stuff with no elec stuff around it, hit it with the brake cleaner.
nabril
itsa300zx wrote:
Wed Jan 10, 2024 4:50 pm
brake cleaner, genius!!
Sprayed it, and things are now their original color.
Thank you.
Refresher course: the attachment is a picture of the alternator, right? Sometimes they're up top or way at the bottom, and it's been a long time since I've had to associate with an alternator.
EDIT - yes it is. I just did a google search...
Return to “Rogue Forum”
