SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Fri Oct 01, 2004 10:32 am
Warm up the engine. Remove all the spark plugs. Then do four compression strokes (aka four needle movements) at wide open throttle. Your numbers are too far above the proper specs, but at least they are consistant.
Standard pressure should be around 156 psi, minimum limit is 128 psi.
