diameter of shifter rod?
srwong
Car: 2009 Altima Coupe 3.5 SE CVT
does anyone know what the diameter of the shifter rod on an altima coupe cvt is?
srwong
bump
mikegtr06
Car: 1995 180sx
You could go measure ....
srwong
I did. Then when I googled it I found different numbers. so I don't know which is the correct one. Do u measure the white part on top, or the metal piece near the bottom
mikegtr06
Car: 1995 180sx
I would say the metal. Ppiece .... Did you find a good shift knob ?
srwong
i found a couple that i liked but they're manual shift knobs. i've been looking into finding an adapter to put on my cvt so i can use manual shift knobs. i need to measure the diameter of the shifter rod, and count the threads. now either i'm just not car smart, or i don't see threads?
srwong
mikegtr06 wrote:There is a button that sucks up and is spring liars. If you were to get a manual shift knob and find a rubber gromett that fit tight, you could use that and just push down when you shift... Add the manual trans trim piece and shift boot for the ultimat deception...
i quoted this from an older post i did because i see that you are the same person that commented on my older post about changing the shift knobs and you said to use a rubber grommet? could you clarify on this?
mikegtr06
Car: 1995 180sx
My guess would be to put a filler inside the shift knob so that it stay on the Rod... It would have to be a berry tight fit on both....You are not that car dumb , there are no threads
FGFCacoupe
Car: Super Black 2008 Nissan Altima Coupe 3.5 SE
Let us know how this project goes
