Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Thu Mar 13, 2003 5:54 am
Measured my Powerstop drilled fronts yesterday 4,400 miles after a rotor truing:
Right front 0.003" Left front 0.004"...........this is about 11,000 miles since the rotors were last shimed and indexed to 0.001" or better........the last truing just replaced them on the lugs they came from. [lack of time]
Out of spec but significantly better than at any previous 10,000 mile increment.
2 brand new front tires [at 1,000 miles] were balanced and rotated Left one was 21 grams out, the Right 8 grams.
21 grams and a 0.003" runout was noticable....thought the rotors were really warped just the tires as usual.......felt 90% satisfactory after the tire balance.
It is the combination of errors that gives you fits but a 0.005" runout with perfect tires starts to get annoying. This is the usual amount that is required to be removed on the lathe: new to replace you have 0.040" [FRONTS] to wear and cut so in theory rotors can be trued 8 times less wear or 6 times [with wear] if you catch them soon enough.
The problem with using the dial indicator on the front surface is that when you put the rotor on the lathe the inside surface is always more warped due to caliper design and lack of air flow.............so an in spec outside may not mean an in spec inside...........usually another 0.001" or more error on inside.
Guess I'll be doing another trueing in 1500 miles.
