diagnostic code p1320 help
Hurrikane
Car: the car
otmy ecu keep putting out code p1320. the book say it is the camshaft position senor. i ran it throw all the stander test and thay all tested fine and with ther car running if i unpluge it from the distridutor it kill the moter .when i reset the ecu the check engine light will come on and then go off at ramdem. need to have it emission tested at the end of the mouth.i love this time of the year. i think i need a bike.
Modified by Hurrikane at 8:41 PM 3/20/2005
Modified by Hurrikane at 7:33 PM 3/21/2005
NISTECH
1320 is ignition primary circuit (the wire that fires the coil) If moving the harness kills your car you need to find the broken wire. where specifically are you moving the harness?
