Since its time for my registration and smog check I decided to spray clean the intakes/plenum through the throttle body. took out and sprayed the EGR valve which contained alot of black stuff in it (carbon build up). Also spray cleaned the MAF and was in a hurry and messed up the maf.
so I start the car afterwards (thats when I found out the maf has been F----d up) cause the car was running like a diesel truck and wobbling and stuff.
I drove the car to work and back next day (not too far). got a MAF and changed it and noticed a huge difference. no smoke now but the car still was not like it used to be.
Started turning off at stops and at idle.
now the car won't start and noticed when i turn the switch on I don't hear the pump when you first hear it upon turn of the switch.
I have an extra FPCM, so I switched it thinking maybe its that but didn't fix the problem.
I don't whether the fuel pump (replaced brand new about a year ago and was Genuine Infinit pump) has fried driving under that condition.
Or is it the fuel pump relay?
Sorry about the long history. Any need would greatly be appreciated
