I guess I've been (mostly) lurking here for over 5 years now. I want to thank everyone who's contributed to this forum over the years, it has been a great resource for wrenching on my Pathfinder.
I'm hoping for a bit of insight on whether I should be worried about my catalytic converters or not.
I have an '04 R50 with A/T, and it has been a real treat to own, I had no idea these things were so reliable, she rolled past 400k (kms) last year sometime, and now I'm hoping to see it get to 500,000
Since I bought it, the CELs been on due to a 0462 DTC, and the diagnostic process led me to a dead end when I couldn't figure out how to repair the PCB in the instrument cluster. I even wrecked my original board because I'm not very good with a soldering iron (I pulled up one of the traces). Luckily I managed to pull a cluster from an '03, and that has served me well for the last 4 years.
Recently I saw the video linked in this thread
post6854380.html so I yanked the cluster out again and reflowed the solder on those 4 resistors. That seems to have fixed the fuel gauge, though I need to 'calibrate' the needle.
Before I pulled the cluster out last time, I grabbed the codes and saw U1001, P0420, P0430, P0462 and potentially one more? I should've written them down but I didn't.
After the cluster repair, I changed the oil/filter and replaced the oil cooler o-rings. Then I did some washing under the hood, mostly trying to clean off the old oil around the cooler, but I did hit the topside lightly with the wash wand. After this my CEL came back, showing U1001, P0420 and P0430. I cleared these codes and have taken multiple short drives (10-20 minutes each) to see if they will come back. So far, I've got U1001 with no CEL(as expected), and no more DTCs.
Is it possible that the U1001 code is caused by the '03 cluster? Should I pursue diagnosis of the U1001 code as outlined at EL-462? Should I follow the process for 0420/0430 diagnosis starting from EC-334? Should I just wait and see if any DTCs come back?
I recently grabbed NDS2 so I have access to some of the CONSULT II functionality, but not all of it. I can see the SRTs, I can log STFT & LTFT, as well as a bunch of other data that I'm generally not knowledgeable enough to interpret. Which is why I'm bringing the problem to the experts!
If I left out any important details, lmk and I'll fill them in.
